Trick Flow "as cast" heads
Old Jul 3, 2008 | 07:27 AM
N4cer's Avatar
Originally Posted by TrickFlowTech
They can't CNC them to a smaller volume. So you are saying they aren't truly the heads as cast prior to CNC. Just that "As Cast" is good marketing for a head that isn't the same exact design.
Old Jul 3, 2008 | 03:04 PM
TrickFlowTech's Avatar
LS1Tech Sponsor
Same head design just a different core to come out with the "as cast" runner.
__________________
Old Jul 19, 2008 | 11:46 PM
N4cer's Avatar
So I'll repeat:
It is NOT truly the same head that they CNC, as it is cast prior to work. The advertising and name are misleading. They are NOT the same head at all. "As Cast" is the same as "different design".
Old Jul 20, 2008 | 12:04 AM
427's Avatar
427
It is the same exact head with a different port core to add volume. The CNC head would be cast with a smaller runner to let the machine have material to cut when the CNC program is run.
Kurt
