H/C setup Whats the numbers going to the tires
Old Apr 12, 2008 | 09:25 AM
guns77's Avatar
Default H/C setup Whats the numbers going to the tires
Just wondering what everyone is putting down to the rear tires and which set up they are using. I will be going with a n/a set up and would like to hear from your guys or gals experiences thanks.
Old Apr 12, 2008 | 09:30 AM
99blancoSS's Avatar
Wow, you need to look in the dyno section. There are literaly thousands of posts that answer your question.
Old Apr 12, 2008 | 09:41 AM
BREWS02WS6's Avatar
Yes, and you dont even have to use the search function that someone will tell you to use any time now. Just read this and the dyno section.
Old Apr 12, 2008 | 09:43 AM
98REDZ's Avatar
^^^ as the other two stated, this question is all too often asked,........its getting mundane. Go dyno it and find out what it puts down and let us know,...thats much more worthy of conversation.
Old Apr 12, 2008 | 10:08 AM
brad8266's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons-65/
All the info you need is there.
Old Apr 12, 2008 | 12:19 PM
guns77's Avatar
Thanks for the info ill check it out, Ill be getting the car dynoed Thursday of week so ill let you all know the results.
Old Apr 12, 2008 | 12:25 PM
Kingc8r's Avatar
Most make 390-425hp....to keep it simple, too many different setups to have one answer. I am always looking in the dyno section to help me decide which setup is best for me
