6.0 oil pan
Old Apr 12, 2008 | 09:30 PM
jt121212's Avatar
Default 6.0 oil pan
im building 408 , will the truck oil pan fit in my camaro or do i need a camaro pan and is there any other little differences that you can think of that will help me out on this swap.thanks jason
Old Apr 13, 2008 | 12:03 AM
Mr. Luos's Avatar
Not a direct answer...
But I re-used my T/A pan on my LQ9 402.
Had to space the windage tray down a little bit for it to clear.
Good luck!
Old Apr 13, 2008 | 12:12 AM
bczee's Avatar
The Truck pan sump is way to deep, would hang below the K-Member.. suggest you pick up the F-Body pan, pickup and windage.
What year Camaro are you putting it in..
Old Apr 13, 2008 | 08:03 AM
jt121212's Avatar
99 ss camaro with d1 procharger
Old Apr 13, 2008 | 08:14 AM
SheldonZ28's Avatar
The pan hung 3" Below my k-member in my '89 iroc, so yes. you definately need to change it out. Sheldon
