valve seals
Old Apr 12, 2008 | 10:03 PM
LS1Z28_98's Avatar
Default valve seals
Was tapping on a new valve seal and the little spring which goes around the rubber at the top of the seal came flying off. Am I screwed or is it not a big deal?
What the hell is that little spring thing anyways?
Old Apr 12, 2008 | 10:08 PM
Randy WS6's Avatar
Take one off the old seal, You need it ,it keeps it sealed to the valve stem
Old Apr 13, 2008 | 01:16 PM
JPH's Avatar
JPH
pull 1 of an old seal. The spring is there to keep a little tension of the seal around the valve stem.
Old Apr 13, 2008 | 07:29 PM
vettenuts's Avatar
Where did the spring go?
Old Apr 13, 2008 | 08:47 PM
Randy WS6's Avatar
At the very top of the seal ,There is a ring cut in the seal for it.
Old Apr 13, 2008 | 10:29 PM
LS1Z28_98's Avatar
Well It broke when I was tapping it in. I found it in the head and thought it was a piece of lint from a rag. Glad I checked.
And thanks everyone, I pulled a spring off of an old seal and rolled it on the new one, and it worked like a champ.
