P/V clearance and cam timing adv. relations
Old Apr 14, 2008 | 08:49 AM
Sam-eye-Am's Avatar
Default P/V clearance and cam timing adv. relations
I have an XER 238/242 113lsa 113icl cam. My heads are 243's milled .030 and I'm running a .040 cometic gasket. I have my pistons flycut on the intake at .095", but the exhausts aren't flycut. I have plenty of P/V clearance on the intake right now, but the exhaust is VERY close. I'd like to gain some P/V clearance on the intake, up my DCR, and bring the peak power RPM down some. I'm thinking that by using my adjustable timing set and advancing the cam 4* for an icl of 109, I could accomplish all of this. This cam is pretty much the same as a MS3. How much exhaust P/V should I gain by advancing 4*?
Old Apr 14, 2008 | 10:12 AM
oldmanwinter's Avatar
You can expect around .007" for each degree you advance. So it will roughly decrease the intake .028" and increase the exhaust the same.
Old Apr 14, 2008 | 10:36 AM
Sam-eye-Am's Avatar
Excellent! That will put me in the range I feel safe with.
