Single timing chain
Old Apr 14, 2008 | 08:40 PM
LS1Birdy's Avatar
Default Single timing chain
I've found on Byunspeed's website that they have a single timing chain with the torrington bearing, but they sell the ls1/ls6 and an ls2...would the ls2 chain kit fit on the ls1 motor?
Old Apr 14, 2008 | 08:48 PM
vettenuts's Avatar
Is this the JP set? I think the only difference is the cam gear due to the forward mounted cam sensor on the LS2. Chain is likely the same.
Old Apr 14, 2008 | 10:16 PM
LS1Birdy's Avatar
yeah its called the N-Motion, but what i've seen on the forums its the same thing as JP. So i'd have to get the ls1/ls6 one then?
Old Apr 15, 2008 | 12:31 PM
vettenuts's Avatar
I think either should work, but am not positive. N-motion is a private label JP for Skoggin-Dickey, you could contact them and confirm. Not sure there is any advantage of the LS2 over the LS1 version, and it may be more money.
