Heads?
Old Apr 15, 2008 | 05:57 PM
Bouvs's Avatar
Default Heads?
Two part question, I want to get AFR's 205cc's... the thing is I want to know what the stock combustion size is so that I may retain stock Compression ratio once they're installed. The second question is if I buy pre-assembled heads from AFR do I have my choice of valve train brands? I want to get Yella Terra Lightweight roller rockers, (I would also like to know stock roller rocker ratio?)
thanks guys.
Old Apr 15, 2008 | 06:15 PM
99blancoSS's Avatar
AFR is a great place to get the YT UL's, I got mine from Tony. Your best thing to do is give Tony Mamo a call at AFR and let him explain it all to you so you dont get convoluted info on here. 1.7 for an ls1 , off the top of my head yes to comression question but check with Tony to be accurate, great guy will take care of you and explain it all.
Old Apr 15, 2008 | 06:18 PM
slt200mph's Avatar
The stock rocker ratio is 1.7..I suggest you call Tony Mamo at AFR and he will be able to answer any of you questions concerning his product ... you are always better off going to the vendor with your questions..nobody will know more about it that he will.
Old Apr 15, 2008 | 06:34 PM
Bouvs's Avatar
thanks guys that sounds like some pretty good advice does anyone have a contact number for me?
Old Apr 15, 2008 | 07:17 PM
99blancoSS's Avatar
877-892-8844 ext 09 or 11 cant remember it has a listing
Tony Mamo
http://www.airflowresearch.com/contact.php
Old Apr 15, 2008 | 07:32 PM
Bouvs's Avatar
sounds good thanks alot now I just have to choose a cam :p
Old Apr 15, 2008 | 08:52 PM
sf35thle's Avatar
228 Cam, Just my .02
