Valve stem seal install HELP!
Shane
I've discovered after installing new seals, that some of them push the top of the valve stem against one side of a guide, you can here that by lightly tapping on the valve stem from 4 directions (if there's no sound, it means seal is pushing stem against guide wall). In some cases valve didn't even fall down under it's own weight. Apparently this misalignment of the seal (not visible nor measurable) will promote valve guide wear? I wiggle them on and then tap in place once on for that last little bit.
It's on all the way when the rubber of the seal is seated on the top of the guide.
That said, I put mine on with the heads off. So you can see when it's installed all the way. I put the valve in last......
