Weird sound in the motor.
Old Apr 19, 2008 | 12:00 PM
92slomaro's Avatar
Exclamation Weird sound in the motor.
I have an 2002 Camaro Z28 and i just changed the oil with Mobile 1 10-30W. When I crank the car up it sounds like it has a clatter. After the motor warms up to running temp it kinda goes away but is still there a little. I'm not sure if the oil pump is not getting out enough pressure. Any ideas??? I want to figure this out before something goes wrong. Thanks.
Old Apr 19, 2008 | 12:42 PM
DaddySS's Avatar
What kind of filter? I assume the noise was not there before you changed the oil?
Old Apr 20, 2008 | 05:31 PM
92slomaro's Avatar
It did it before i changed the oil. It now has a Mobile 1 filter in it. Once it warms up it stops. sounds like the lifters don't get enough oil. I'm thinking about an ls6 oil pump, alot of people i have read up on put it on, I want to see some more info on it like how much it cost and the install.
Old Apr 20, 2008 | 05:33 PM
Z28LS1camaroguy's Avatar
sounds like piston slap or possibly just valvetrain noise, if it goes away when warmed up then whats the problem??
Old Apr 20, 2008 | 10:52 PM
92slomaro's Avatar
well this is just my first ls1 so i don't want anything getting messed up if you know what i mean. Is piston slap anything o be concerned with or does it just happen. and by the way where did you get your headlights they look sweet.
Old Apr 21, 2008 | 05:39 AM
s346k's Avatar
my elessjuan did the same thing after an oil change. it's like the engines dislike new oil...i beat the hell out of mine for 25k miles with regular oil changes and had 0 problems with anything engine related.
Old Apr 21, 2008 | 09:21 AM
00_transam_vert's Avatar
+1 On Piston slap. And No, its nothing to worry about, just don't beat on it till she's good and warmed up.
