TSP 231/237 Cam
Old Apr 19, 2008 | 10:43 PM
CamaroGuy27's Avatar
Default TSP 231/237 Cam
How many people out there are running the TSP 231/237 Cam. As a matter of fact, how many of you are DD this cam, and would you recommend it as a DD?
Old Apr 20, 2008 | 08:30 AM
anyone?
Old Apr 20, 2008 | 08:32 AM
big reg's Avatar
I dd their 233/239 112 lsa cam. It is the replacement in their lineup for the 231/237 which was ground on Lunati lobes I believe. The 233/239 is on Comp XE-R lobes.
Old Apr 20, 2008 | 10:41 AM
TXZ28LS1's Avatar
i was looking into that cam myself. but i went with MTI X1.. the 231/237 is a good street cam also. do some searches on speed inc si5. there should be alot of results with that cam.
Old Apr 20, 2008 | 04:47 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The 231/237 camshaft was a good camshaft, but cams have advanced a little bit in the last few years. Our Torquer 3 camshaft will make more peak power & start making power much earlier than the old 231/237 camshaft. We don't even sell the 231/237 anymore because we've found so many other camshafts through engine dyno testing.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Apr 21, 2008 | 12:03 AM
NVR_SPDS's Avatar
Our 00 has the 231/237 and its an ok cam.. Easy to DD, just takes a little getting used to going from stock cammed car. Not too impressed with the numbers.
