Pulling engine out the top...with tranny or w/o?
Old Apr 22, 2008 | 11:37 AM
LSxChevelle's Avatar
Default Pulling engine out the top...with tranny or w/o?
I see a lot of pics of people pulling the motor out the top and I'm ready to pull but would like to keep the tranny in the car. Enough room to just do the bellhousing bolts and slide the clutch off the splines?
Old Apr 22, 2008 | 11:40 AM
99ssleeper's Avatar
I pulled mine out the top, but the heads were off the car. I don't think you'll have a problem. I used the CarChopInc.com lift plate with hook int he front hole to get max angle. Worked like a charm.
Old Apr 22, 2008 | 11:44 AM
Left the trans in the car?
Old Apr 22, 2008 | 12:04 PM
2001 Pewter WS6's Avatar
Restricted User
In a Chevelle, it will all come out together. In a 4th gen Fbody, the tranny has to stay
Old Apr 22, 2008 | 12:07 PM
It's a 4th gen. Gotta do rings for a friend. Looks like I got the tranny bound a little... Drivers side is seperated by ~3/4" and the pass side is like 1/8"...
Old Apr 22, 2008 | 07:13 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I pulled the motor(with heads) and the T56 out through the top in my TA
