Timing chain play
Old Apr 22, 2008 | 03:46 PM
ls1slow's Avatar
Default Timing chain play
I just changed my cam and when i opened it up it was kinda loose on the side in between the gears. When i put it back on it was it was super tight but the sides still had the play in them is this ok is it suppose to be like this.
Old Apr 22, 2008 | 04:21 PM
vettenuts's Avatar
Did you install a new chain? In a nutshell, yes there is some slack.
Old Apr 22, 2008 | 05:56 PM
ls1slow's Avatar
No i didnt but if there smoe slack i think im good
Old Apr 22, 2008 | 08:10 PM
tylerdj's Avatar
I had a small amount of slack when I did my cam swap.
Old Apr 23, 2008 | 08:45 AM
robertbartsch's Avatar
Next time swap the timing set and chain since it is not that much dough. Double chain sets stretch less.
Old Apr 23, 2008 | 09:05 AM
DONAIMIAN's Avatar
The factory chain is designed to be loose.
