torque specs for heads
ok stripped out a bolt. i want to know the torque specs for the heads.
im using arp head studs
i know the M11's are 20,40,80 ft lbs
but what about the smaller m8 bolts are they the same.
i feel like a retard so help me out.
I just did the exact same thing with stripping out a bolt and i put arp head studs in and torqued the little ones to 25ft psi. those dam alumium threads can't take much abuse.
so what are the large studs torqued to?
The nuts on the studs should be 65 ft. lbs. for an aluminum block and 70 ft lbs for an iron block as per ARP instructions.
