Installing timing cover
Old Apr 26, 2008 | 06:49 PM
verano29's Avatar
Default Installing timing cover
I'm installing my timing cover now. Some folks say to just use a dab of rtv on the edges where the oil pan meets the block other say to use it on the entire bottom of the timing cover. Which is the correct way to do this? This is for a 98 vette BTW.
Old Apr 26, 2008 | 07:40 PM
verano29's Avatar
Anybody?
Old Apr 26, 2008 | 07:48 PM
405HP_Z06's Avatar
corners only.
Old Apr 26, 2008 | 07:54 PM
verano29's Avatar
The service manual talks about using a special tool to align the cover. My plan was to loosly install it then install the balancer and let that center the timing cover. How did you do it?
Old Apr 26, 2008 | 08:07 PM
Zitty'sZ's Avatar
Just the way you described it Mike . I'm glad your on the home stretch now !
Old Apr 26, 2008 | 09:05 PM
vettenuts's Avatar
Originally Posted by 405HP_Z06
corners only.
Aaron,
Curious, you re-used the pan gasket and didn't coat the timing cover bottom?
Old Apr 26, 2008 | 09:35 PM
verano29's Avatar
Originally Posted by vettenuts
Aaron,
Did you throw a bead on the bottom of the timing cover?
Old Apr 26, 2008 | 10:03 PM
405HP_Z06's Avatar
Aaron,
Yes sir, I used RTV only on the corners. I wasn't going to drop the oil pan just to replace the front part of the gasket, it's all or nothing. Too much of a PITA. No problems with leaks.
Old Apr 27, 2008 | 07:59 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Only the corners, like said.
Old Apr 27, 2008 | 08:01 AM
vettenuts's Avatar
When I did the first cam I coated the bottom of the timing cover, should be fun getting it apart again. If its in good shape, maybe I'll just do the corners this time.
Old Apr 27, 2008 | 08:36 AM
Shawn MacAnanny's Avatar
I just did the corners and aligned the timing cover to be flush with the block so the pan would mate flush. I assumed the balancer would be centered then.
Old Apr 27, 2008 | 10:10 AM
Tally TransAm's Avatar
i always do the whole bottom of the cover, but it on but leave all the bolts loose, install the crank pulley, then torque the timing cover bolts. never had problem on countless installs
Old Apr 27, 2008 | 11:51 AM
vettenuts's Avatar
Ever pull one apart after this method? Curious as to how well it came apart.
Old May 12, 2008 | 09:10 PM
BadLtBlu99TA's Avatar
Question balancer
whats the best way to install the Balancer ? is there a special tool ?
Old May 12, 2008 | 09:37 PM
I stuck mine in the oven @ 200 degrees for about a half hour then slid it on half way, tapped it on with a 2x4 to almost 3/4 of the way and used the old bolt to tighten it down the extra 1/4 of the way. It wont distort the rubber dampner inside like some will suggest. It doesnt get hot enough. I left it facing up just incase it did but the rubber wasnt even tacky when i removed it from the oven.
Old May 13, 2008 | 06:27 AM
vettenuts's Avatar
Yes, but you can make one for about $20.
Old May 13, 2008 | 08:57 AM
Ever pull on apart after this method? Curious as to how well it came apart.
yeah comes right off
Old May 13, 2008 | 05:01 PM
Default balancer
Thanks ... again !!!
