How long will the ls6 springs last?
Old Apr 27, 2008 | 10:49 PM
Christobevii3's Avatar
Default How long will the ls6 springs last?
I have a 5.3L with the ls6 valve springs. I am running the comp camps 265hr high lift cam and am wondering how many miles I can run these before i should redo them?
Cam specs
XR265HR-15 High Lift Comp Cam
212/218
.558/.563
115 LSA
1,500 to 6,800 range
Old Apr 27, 2008 | 11:18 PM
jay_lt4's Avatar
mine only lasted 1 summer of driving then i started having valve float at 6200 rpm
swapped to pac-1218 springs and everything has been fine since then running to 6800 rpm+
what do you expect from a set of springs that you can get for $50 a set
Old Apr 28, 2008 | 02:06 AM
kingsey's Avatar
just ditch them and buy 918s
Old Apr 28, 2008 | 10:56 AM
Fb0dy0nly's Avatar
running that setup on the LS6 springs is asking for trouble. Spend the extra $100 and get some good springs so you dont have to spend a few grand down the road to fix your motor from broken springs flying all over the inside...
Old Apr 28, 2008 | 12:08 PM
litle88's Avatar
Cam specs
212/218
.558/.563
115 LSA
WOOOOWWWW!
Ls6 springs are only rated to a .570 lift!
That is way too close for me!
Just go with a better set of springs or it might cost you alot more later!
Old Apr 28, 2008 | 12:32 PM
I thought they were rated for .580? My redline is set to like 6200 or 6300rpm for now too, if that effects anything. The stock ls6 cam is around .555 lift correct?
Thanks
These springs
Link
Old Apr 28, 2008 | 02:15 PM
zman1969's Avatar
Default springs
I believe the Ramp rates of the Comp cam is too aggressive compared to stock lobes(read fatigue).I'd hate to regret not spending now and costing ALOT later
my .02c
Old Apr 28, 2008 | 04:08 PM
litle88's Avatar
Thanks
These springs
Link
Dont you believe them! What color are they?
look at this...
http://www.sdparts.com/product/12586...sameasLS2.aspx
http://www.texas-speed.com/shop/item...d=211&catid=48
Just my .o2, but ultimately its your ride.
Old Apr 29, 2008 | 09:34 AM
JBIRD02's Avatar
probably wont last long at all with that lift. So far, my LS6 springs have lasted 20k miles, but my cam is only .525 lift.
look at this...
Whats wrong with the springs from the link he posted? Thats where I got mine from.
Old Apr 29, 2008 | 10:13 AM
slowmofo's Avatar
yellow and orange LS6 springs are good to .580 lift, but like zman said the ramp rate of that cam is what will kill them.
Old Apr 29, 2008 | 10:17 AM
robertbartsch's Avatar
Get the double springs which are very stout and last a long time with higher lift cams.
My cam and double REV springs have been in my car for six years now; no issues!
Consequently, I am very glad I used doubles....
Old Apr 29, 2008 | 10:50 AM
GuitsBoy's Avatar
Those are comp XE Lobes, right? Its not the lift, its the ramp rates of the lobes themselves. I wouldn't be surprised if even fresh LS6 springs have float on that cam. Id get some real springs ASAP.
Old Apr 29, 2008 | 12:22 PM
Alright, I'll change out the springs to the comp cams that use the stock retainers next month.
