Weight difference between Trick Flow 215 and ET 215s?
Old Apr 30, 2008 | 05:05 PM
98camaroLS1M6's Avatar
Default Weight difference between Trick Flow 215 and ET 215s?
I was just wondering if anyone knew exactly how much heavier the ET 215s are compared to the Trick Flow 215s? Thanks!
Old Apr 30, 2008 | 05:14 PM
mchdg86's Avatar
I wouldn't think one would weigh more than the other and if there is a difference it won't be enough to make a difference. I do know the trick flows have a 13.5 degree valve angle compared to 11 degrees for the ETPs.
Old May 2, 2008 | 08:54 AM
Mike@TEA's Avatar
A bare unassembled cnc ported Trick flow weighs just over 22 lbs. An LS-6 weighs ~19 lbs. A DART weighs 21.5 lbs. I do not have an ET head around that I can weigh. Add 5-6 lbs per head for components.
Old May 3, 2008 | 12:46 AM
Thanks for that info Mike. If you find out the weight of an ET 215 let me know, thanks!
