help cam??
im wondering,my wife has a a4 t/a she wants full exhaust and some cam action, is the tsp233/239 a good cam? and about what lift is it??? and what are some other good mild cams??
Having said that, Something in the 224-upper 220's is usually good for a full bolt on car that needs to be a reliable DD. I consider the tsp233/239 to be in the lower range of a large cam, not that a lot don't DD bigger cams on here. I will report on my PredatorZ speced 230/234 .612/598 111+2 XFI/XE-R in the very near future. Should be a polite DD with lots under the curve without giving up too much up top. A4 with 3.23's and the mods below and hoping for +410/375. Others have done better with similiar setups but I don't wanna set my sights too high. Search around on here and you'll find what you want or get one of the gurus on here to spec you one. Good luck
