Piston Carnage - Pics Inside
Old May 2, 2008 | 11:47 AM
knute_gis's Avatar
How much boost were you running?
Old May 2, 2008 | 01:13 PM
Silver02Z28's Avatar
Only about 8psig on meth. I'm sure I ran the methanol out once or twice come to think of it. That's probably what did it, but why just one side?
Old May 2, 2008 | 02:19 PM
BadgeZ28's Avatar
Its pretty risky honing cylinders in the car with crank/cam and bearings in place. Good Luck
Old May 2, 2008 | 02:32 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The second pic is exactly what my #7 piston looked like but I also spun two rod bearings
Old May 5, 2008 | 03:21 PM
Default Update - New (used) slugs are in!
And the compression is 180+ cold all around. It runs good so far. Much stronger than before and no blow-by or smoke. It fired right up on the first crank, no knocks, pings or groans. The starter went bad after a few starts and stops, but it bump starts right away.
I want to put a few hundred miles on it before I get too happy about it. Rebuilding the bottom end while the block is in the car is a first for me. I've done plenty on the stand, but we'll see. I tried to keep everything as clean as possible while honing.
Old Aug 28, 2010 | 03:44 AM
I just re-read my thread after two years. This engine is still running strong after honing and slapping in four used pistons/rods while the engine was still in the car. It burns a little oil when I really get on it, but it still pulls strong two years later.
The car has been N/A since the pistons broke, but I'm planning a new FI build in the near future.
