What head gasket?
Old May 8, 2008 | 03:25 PM
dave70's Avatar
Default What head gasket?
I'm looking for the right head gasket to use with a 408 iron block. It has the 241 heads with dished pistons and will see about 9psi with a rear mount turbo is it worth the extra $$ for the cosmetics or will the GM MLS gaskets work ok with ARP studs?
Old May 8, 2008 | 09:36 PM
dave70's Avatar
anyone?
Old May 9, 2008 | 12:07 AM
99blancoSS's Avatar
gm mls and arps are fine.. cometics are an mls as well :
Multi Layered Steel
Old May 9, 2008 | 01:02 AM
BuBbABFP's Avatar
Multi Layered Steel
+1
I used GM MLS gaskets and ARP Studs.
Old May 9, 2008 | 08:50 AM
GuitsBoy's Avatar
GM MLS gaskets are great. Make sure you get the 6.0L gaskets and not the 5.7.
