upgrade rod bolts - part #?
also - are these gm replacement bolts just like the katech bolts in the sense that i can simply remove one and put the other in place of it? one at a time..
thanks for your input.
Personally I would look into the ARPs if youre on a budget. Much stronger than the 01+ stock bolts. Regardless of the disclaimer, theyre also direct replacement. Id much rather trust a directly replaced ARP bolt with a disclaimer than a GM bolt.
Kinda falls under the philosophy "do it right or don't do it at all"
