advise?
I am asking because i am new to engine building, and my friend (a honda guy) said the heads and cam need to be closely matched.
Also I was checking out a site called flatlander racing for the rebuild kit. Has anyone delt with them before? Any good or bad reviews? They seem to be the most reasonable for a master rebuild kit for 1209 which includes Pistons, Rings, Gaskets, Cam Bearings, Rod Bearings, Main Bearings, Oil Pump, Freeze Plugs, Camshaft, Lifters, Pre-lube, and Timing Set, and Valley Pan (if applicable).
