How do u know engine model??????????
Old May 11, 2008 | 03:46 AM
LS1SS4ever's Avatar
Exclamation How do u know engine model??????????
If u would buy engine only how do u know which model it is? If the owner has many engine and he doesn’t know is there number or something else??
Old May 11, 2008 | 04:39 AM
Shawn MacAnanny's Avatar
If you are reffering to LSx engines the easiest way it to look on the head. It will be stamped on the driver side rear and passenger side front of the head right above the exhaust port. it will say 241, 853, 243 or something. This will help determine the year and engine type. You can also get the casting number off of the rear of the block driver side. Also behind the flywheel there will be a 5.7, 6.0L etc stamped on it.
Old May 11, 2008 | 01:22 PM
LS1SS4ever's Avatar
If it is GTO engine and has 241on the head, u know they use ls1 from 03to 06 model. How do I know the specific model?
Old May 11, 2008 | 03:53 PM
241 heads were used on fbodys from late 2000 to early 2001, on vettes from 2000-2004, and im unsure of what year GTOs but the first few years i know they had LS1s which im assuming had 241 heads. The later years would he LS2s which would have 317 on their heads i beilive. I'm not really sure how you would tell which model it was from. You could look at the accessories i suppose. Why does it matter?
Old May 11, 2008 | 04:11 PM
RA4926's Avatar
241 heads were used from late 2000 to the end of production in f-bodies.
Old May 11, 2008 | 04:20 PM
yeah sorry i meant 2002. I dont know why i meantioned 'early'
Old May 13, 2008 | 06:59 AM
radkon's Avatar
Get the block stamp and the head number and we can give you a year range for the engine.
