Cam help...please
Old May 11, 2008 | 06:34 PM
camaroIroc's Avatar
Default Cam help...please
I have a 1999 5.3 v8, and I have an LS2 cam. I have read and read about guys needing cam sensors and different cam gears/chain.....do I need all this stuff? I have the cam in the block and I have a new 5.3 timing chain, but I am using the stock gears...when rotating the engine over-everything seems to be operating correctly....I can understand the whole tuning process..any help would be appreciated.
Old May 11, 2008 | 08:42 PM
Paint_It_Black's Avatar
You should be ok. My understanding is not the cam that matters, it's the number of teeth on the reluctor wheel. If all you did was swap the cam out, you should be good to go.
Old May 12, 2008 | 01:49 AM
ReedBooth's Avatar
So long as the cam sensor ring is the same as a GenIII Cam then you should be good. The ring is the off center circle at the end base of the cam, where your sensor picks up cam position.
