Any reason not to use 99 6.0 block & crank?
Old May 12, 2008 | 10:09 AM
85Iroc's Avatar
Default Any reason not to use 99 6.0 block & crank?
not sure if this is the right section. Any differences or weaknesses in the 99 6.0 block & crank vs. a newer model that should keep me from using it for my build?
Old May 12, 2008 | 12:06 PM
Jantzer98SS's Avatar
The crank has a longer hub in the back and won't work with a M6 or 4L60e. You would have to use a Th350/400 with an LS1 specific converter with the longer crank snout. Also need a 6.0 flexplate (an older style 99-00 or a newer one and take the little hub spacer out of it)
No weaknesses that I know of. Mine rips.
