Do I need a timing chain?
Old May 13, 2008 | 07:56 AM
WstTexas's Avatar
Default Do I need a timing chain?
Do I need a timing chain and if I do, which one?
I am planning on doing my cam install in the next couple of weeks and the only thing I have left is to decide on the timing chain. Here is what I am going to install:
Comp Cam 224/224 .581/.581 112LSA +4
Comp Cam Revised 918's
Comp Cam Chromoly 7.4 pushrods
Melling Hi-Volume Oil Pump
I was thinking about upgrading to a LS2 chain, but wasn't sure if I needed the entire set, just the chain, or an adjustable set. Any advice is appreciated.
Old May 13, 2008 | 08:02 AM
02BEAST's Avatar
I put the LS2 timing chain when I did my cam swap you might as well since everything is apart you don,t want to put that much stress on the stocker with a new cam.
Old May 13, 2008 | 08:07 AM
s346k's Avatar
ls2 chain is all you need. like $30 from gm.
Old May 13, 2008 | 08:33 AM
vettenuts's Avatar
SDPC now also has a drop in IWIS chain for about $42.
Old May 13, 2008 | 08:36 AM
98RedBird's Avatar
LS2 chain would suit you just fine.
Old May 13, 2008 | 08:38 AM
GuitsBoy's Avatar
For the price, its a nice upgrade just to be on the safe side.
Old May 13, 2008 | 08:47 AM
WstTexas's Avatar
So everyone agrees that I just need the chain and not the entire set. Looks like I will be ordering a chain today then.
Old May 13, 2008 | 08:48 AM
GuitsBoy's Avatar
Correct. On a more advanced setup, a stroker, or blueprinted motor, then youll want an adjustable kit. But on a cam only swap, just replace the timing chain and go have fun.
Old May 13, 2008 | 08:54 AM
tylerdj's Avatar
Yep. The ls2 will be fine for your setup.
Old May 13, 2008 | 09:13 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Truth, you just need the chain. We have the LS2 chain for 37.52, or an IWIS chain for $42. Either will be adequate for your needs and works with the stock gears
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 13, 2008 | 09:25 AM
WstTexas's Avatar
If I order the LS2 can you give me free shipping to Midland, TX 79701?
Old May 13, 2008 | 09:53 AM
pm received and returned
__________________
Old May 13, 2008 | 10:24 AM
vettenuts's Avatar
However, when only replacing the chain it is always prudent to fully inspect the sprockets for problems.
Old May 13, 2008 | 10:32 AM
Hennytime's Avatar
my stocker was fine, so i kept it, im only spinning to 6200 anyways
Old May 13, 2008 | 10:36 AM
BlackScreaminMachine's Avatar
Internet Mechanic
The stocker will have some slack in it. But its fine, if it has 60+k maybe consider changing it. its just a PITA due to the oil pick up tube and if you mess the seal up, your tearing it back down again.....
Old May 13, 2008 | 10:37 AM
WstTexas's Avatar
Yeah, I only plan on going to 6200-6300, but I figured it is better to be safe than sorry. I don't want to tear everything apart and do the install just to have the chain break a week later. I live by the saying measure twice, cut once, LOL.
Old May 15, 2008 | 02:47 AM
WstTexas's Avatar
Just bought a LS2 Timing Chain from YANK! Thanks for the good deal, $38 and free shipping to my residence.
