Head Bolt problems?
if you have a 2004 6.0 get the bolts for a 2004 6.0 engine
2003 and older 6.0L = 2 different length bolts and the short 10mm ones
2004 and newer 6.0L = all same length bolts and the short 10mm ones
the stock bolts work fine with the L92 heads, the heads dont matter, ls1,ls2,l92 you need the bolts to match your short block
