Recommended Bearing Clearances
Old Aug 8, 2003 | 07:35 AM
99 1LE SS's Avatar
Default Recommended Bearing Clearances
What is the recommended bearing clearances for a Nitrous motor? All bearings are coated and STD in size with stock mains, stock crank and lunati pro billet rods. I have .002 on the #1,2,4,5 main caps #3 is a touch above .0015. All rods are .0015. Thx in advance
Old Aug 8, 2003 | 10:40 AM
Vents's Avatar
Default Re: Recommended Bearing Clearances
if you dont mind me asking, what tool specifically are you using to get these measurements? dial indicator?
Old Aug 8, 2003 | 02:04 PM
99 1LE SS's Avatar
I am using Plastigage for all measurments.
Old Aug 12, 2003 | 05:11 PM
Vents's Avatar
well, the #3 seems a bit on the tight side, but would probably be fine. what kind of break away Tq does the crank show all torqued to spec?
Old Aug 12, 2003 | 05:31 PM
Reckless's Avatar
Super Moderator
My experience with Plastigauge is that it reads a little on the tight side. I would shoot for .002 - .003 on both rods and mains.
