need advice on ptv clearance
Old May 18, 2008 | 10:50 AM
07gsxr750's Avatar
Default need advice on ptv clearance
i am doing my heads and cam this weekend and needing advice on ptv clearance, the heads are etp 215's, the cam is a comp grind 231/253,621/615@111+4, i heard the etp's are good for ptv because of the of the valve angle, but wanted some advice on it. thanks, and not sure what the mill is but i know the cr is 11.5:1
Old May 18, 2008 | 12:31 PM
PREDATOR-Z's Avatar
Ok on intake, measure exhaust, hot dang this is a biiig exhaust split,are you sure there is no typo?
Old May 18, 2008 | 03:58 PM
07gsxr750's Avatar
sorry my misprint, its a 231/235,621/615,111+4 cam
Old May 18, 2008 | 05:44 PM
miami993c297's Avatar
You will be more than fine...thanks ETP and the 11*rolled valve angle!!!
With more duration and less volume plus a tighter quench my engine is around 0,100 both side, more than fine for revving to 7500rpm.
Christian
Old May 18, 2008 | 06:00 PM
07gsxr750's Avatar
nice numbers with that setup, i cant wait.
Old May 18, 2008 | 06:06 PM
thanks, what kind of numbers did you put down with that setup
346ci NA stock short block on pump gaz easy daily driver...511rwhp and 455rwtq:
Christian
