OK anything else
Old May 22, 2008 | 01:50 PM
tasilver's Avatar
Default OK anything else
I should get my car back next week (they have had it for a month). I am having a TR224 112lsa cam installed, ported ls6 oil pump, new timing chain, 243 CNC heads with valve job, ferra (I think i spelled it right) valves. The springs and pushrods were part of the TR cam package. I would like to make the most of my set up. I know I can by a fast intake (I have a LS6 now) and polished TB for a few extra ponys. Can anyone think of anything else that I would want done before I get the car dynotuned.
Old May 22, 2008 | 03:08 PM
massls1guy's Avatar
If you still have your stock injectors you should replace them when you get your tune.
Old May 22, 2008 | 03:17 PM
JScamaro's Avatar
Some other things you could do are injectors like another one said, pulley, roller rockers, cosmetic gaskets for more compression, and of course the Fast 92mm intake/NW 90mm tb.
Old May 22, 2008 | 05:11 PM
tasilver's Avatar
How much power from new injectors for my setup? I am ordering a underdrive pully aswell.
Old May 23, 2008 | 08:20 PM
TransAmcoupe98's Avatar
head gaskets can move the compression up a little. Eliminate air conditioning....
Old May 23, 2008 | 08:53 PM
massls1guy's Avatar
The problem is your stock injectors will be maxed out with your new combo. Since you can't change injectors without getting the car re-tuned now is a good time to do it. I brought them with me when I got tuned so my tuner installed them and then set the tune for them correctly.
You probably can go with the ford racing 30# injectors (which flow 36# in an f-bod due to higher fuel pressure than a mustang). I would tell your tuner all your mods and see what he suggests for injectors.
I got my injectors from SDPC:
http://www.sdparts.com/product/M-959...jectorKit.aspx
