help have some trouble
Old May 24, 2008 | 11:52 AM
SilverBulletZ's Avatar
Default help have some trouble
ok i ran a 14.3 wih my 98 camaro z28. i came home and put the computer to it and i had 4 and 6 cylinder misfire. prolly the plugs. and my map sensor is reading .99 v . shouldnt that be higher? and i went from 3rd to 2nd by accident and now one of my rockers are taping. did i bend a push rod? need help guys thanks.
Old May 24, 2008 | 01:53 PM
socmguy's Avatar
Restricted User
pull all those PRs out and roll 'em on some glass. 14.3 is a garbage *** time for an F body. You're definitely going to have to make up for that.
Old May 24, 2008 | 05:02 PM
im gunna do this all tomm at my shop. i had everybody off the line but with the misfires in the 2 cylinders didnt have any top speed.
Old May 25, 2008 | 02:19 PM
ok so there is no bent push rods. found out that passenger side was clean and driver side wasnt. driver side push rods were cloged and wouldnt let oil go to top to rockers and that was the tapping noise. i have the push rods soaking in fresh oil over night and tomm ill put the car back together and change the oil. should i use some of that lucus treatment to clean the driver side head so it will come close to the passenger side? and since this was like this is this y i went through so much oil burning?
