Compression maybe?
Old May 26, 2008 | 05:14 PM
blakelh86's Avatar
Default Compression maybe?
Hello i was wondering if someone would be able to help me out? Here is a list of the mods done to the motor, the thing is is that its only pushing 400/400 to the wheels and it seems low to me. So i was wondedring if it could be the compression? And if so, what kind of compression could i do to be ablt to still run 93 octane?
370 cid forged shortblock
9.2:1 Compression
scat forged rods
speed pro forged pistons
new OE replacement lifters/Trays
cloyes non-adjustable timing set
ARP Main studs
ARP head studs
Clevite H bearings in cam, rods and mains
Patriot stage 3 LS6 Style heads
cam specs 228/232 @.050 with ~.580 lift
all new GM gaskets
TSP air lid
LS6 Intake
ported LS6 oil pump
Comp hardned pushrods
Mac headers w/ true duals
160 T-stat
ASP underdrive pully
ported stock throttle body
and it also has a wet plate kit with a 100 shot
any info would be greatly appreciated. Thanks
Old May 26, 2008 | 05:31 PM
johnLs1camaro's Avatar
crap your only making 400/400 with that setup somethings really gotta be wrong is your car auto or m6...has it been tuned???
Old May 26, 2008 | 05:42 PM
Eagle02's Avatar
9.2 CR is not a problem, but it is a bit on the low end. Perfect for a power adder though! You'll need to get that thing on a good scanner and see whats happening because its definitely not making the power that it should be.
-Eagle
Old May 26, 2008 | 07:04 PM
blakelh86's Avatar
its a m6. the previous owner said it is tuned for a 100 shot, but i still dont see how its only 400.
Old May 26, 2008 | 07:12 PM
Shawn MacAnanny's Avatar
What tire psi was it dynoed with? I dynoed my 01 Z06 at 410rwhp with ET ls6 heads, 238/242 cam and such. Broke an output shaft, differential and valve spring (replaced all springs), pumped tires up from 15psi to 30psi and dynoed again at 465rwhp.
Old May 26, 2008 | 08:55 PM
blakelh86's Avatar
I have no idea what pressure because the previous owner had the dyno done, he just gave me all the reciepts and the dyno printout. He pretty much built it to have it blown, guessing the low compression but im not going to be doing any of that. Im just sticking to the nitrous. Is there anyway to get higher numbers from this setup?
Old May 26, 2008 | 09:01 PM
Could jsut be your compression. You can mill the heads, get thinner gaskets, but if your pistons are dished there's not much you can do. You could try swapping your bottom end in the FS forum for a high compression one. Or sell it. Or jsut save up and buy a SC. That's what i'd do.
Old May 26, 2008 | 09:06 PM
blakelh86's Avatar
what kind of compression ratio could i run and still run pump 93 octane?
Old May 26, 2008 | 10:41 PM
ss.slp.ls1's Avatar
11.0-11.5:1 shouldn't be a problem with the right tune.
