How about this setup?
Old May 27, 2008 | 12:19 PM
camaroguy26's Avatar
Default How about this setup?
I hope It works cuz I just ordered everything and need it all together by fri lol. But if you don't know my other thread I'm on leave, have to leave sat to get back to duty, and my spring shattered, bent the valve, other good stuff. So here's my new setup on the way.
I have AR Long Tubes 1-7/8" FAST 78mm manifold, MTI Lid, SI007 reverse split cam (I believe 224/228 .588 on 113), ported oil pump. on the way I have the DART PRO 1 205cc runners 62cc chamber assembled heads, Comp Lifters, LS2 lifter trays, Harland Sharp Shaft mounted Rockers (not the full length shaft, the paired shaft) NGK55 Iridium plugs, Taylor 8mm wires. Before with the stock heads, lifters, and rockers it was making 400 RWHP without the AR Long tubes, I had pacesetter mid-lengths on it. Anyone wanna guess what I'll get now? hehe.
But I'm still needing center bolt valve covers and coil brackets so if someone has a set let me know I need them by Thur!!!! I'm hoping my stock length chromoly pushrods are the right length. I have a checker on the way also but does anyone know off the top of their head? I believe that's all I need. I have head bolts and gaskets on the way also. I'm excited though! Something so very bad turns into something outstanding! hehe
Old May 27, 2008 | 03:37 PM
SOMbitch's Avatar
The base circle on your new cam is smaller than stock meaning you will need a little bit longer PR. Use your new PR length checker
Old May 28, 2008 | 02:14 PM
yeah I plan to but I hope the stock 7.4 will work. Running out of time fast!
Old May 28, 2008 | 03:07 PM
SOMbitch's Avatar
430rwhp.
Old May 28, 2008 | 03:08 PM
SOMbitch's Avatar
425rwhp.
