need help ls1
Old May 27, 2008 | 03:36 PM
superLS1camaro's Avatar
Default need help ls1
i had a rod bearing go out on my ls1.i hear the ls1 are bad for the rod bearings going out? what can i do.so this will not happen again ?
Old May 27, 2008 | 04:07 PM
ss.slp.ls1's Avatar
Maybe shim the oil pump relief valve to bump up oil pressure or get a ported oil pump. Maybe do the LS6 pcv conversion to reduce oil consumption. Otherwise there is not much you can do besides keeping an eye on your oil level.
Old May 27, 2008 | 09:14 PM
07gsxr750's Avatar
rod bolts, stock ones stretch over time
