Broken Intake Bolt Question. New Heads?
I ended up going to Autozone and bought the EZ-Out and attempted it myself as a friend said to drill straight in the middle. I was not completely sure how to use it but I now ended up just drilling a large hole through the bolt but its still stuck in my head. I have since put the intake back on with the new bolt but it will only go in a few threads as it stops where the last one is locked inside. My options:
1) Get a cheap set of 806 heads and replace the heads. Is this hard?
2)Upgrade to 241 or 243 heads but buy new valve covers and coil brackets.
I want to make sure nothing happens to my motor since one side of the intake (very front right bolt) is not tightened down. Someone let me know any problems I may face if I don't get this done asap? Thanks
Whats on the other end of the intake bolt hole? If I kept tightening the new intake bolt down would it push the old bolt out the bottom of the hole?
I tend to tap the EZ out lightly with a hammer to get it to stick. I've also found that the rectangular EZ out bits work better than the drill bit shaped ones.
If tapping on it doesnt help, try to get a left hand drill bit as mentioned above.
I don't remember if the hole is a through hold or not. Is the head still on the engine and in the car, or is it out on a bench?
And the heads are still on the car. I wish they were off, it would be much easier.
)There shouldn't be too much effort required to unscrew the broken bolt, no thread locker should have been used.
Here are some examples of how to extract a screw:
http://homerepair.about.com/od/inter..._extractor.htm
http://www.asashop.org/autoinc/may2003/techtotech.htm
http://www.newmantools.com/drillout/how1.htm
http://www.motorcycle.com/how-to/how...rews-3440.html
I started with the last 2 bits, M5-6 3/16-14. I started to drill a hole in the center with the drill bit then put the extractor in next and drilled counter clockwise but nothing came up so then i went to the next size, M6-8 1/4-5/16 which this did nothing either. I think i stripped it out with this next larger extractor. So what could I push inside the hole now that would lock inside and help back it out? My fear now is that I am too close to the threads so I do not want to use the EZout any more for fear of cross threading the hole.
M6 is awfully close to the diameter of the bolt itself, isn't it? I thought those were 6mm bolts. Its been a while since I messed with any of that.
It sucks when they strip out like that, it does happen. You need to be able to get in there deep, but it sounds like you don't have much bolt in there.
The only other thing would be to hammer a junk screwdriver (or allen wrench, or even one of the bigger extractors) until it is tight, then unscrew it with Vice grips or something.
http://www.dsmtuners.com/forums/arti...-helicoil.html
http://www.roadstarmagazine.com/modu...rticle&sid=233
So where do you buy this helicoil set at? And would I be able to use the original intake bolt for the helicoil spring or would I need to find a new bolt? Seems pretty simple, drill out larger new hole, insert helicoil spring inside, and then bolt works in the new spring. Where does all of the other pieces of metal go that I shaved on top of? Isn't the valve just below the head? Learned my lesson. lol
I remembered my old thread about making pseudo alignment studs when port matching a fast intake: https://ls1tech.com/forums/generation-iii-external-engine/525974-fast-90-intake-owners-have-you-tried.html
and I do mention the thread being 6mm
I think the small head bolts are 8mm in diameter (could be wrong, doing this frommemory) as are the rocker bolts. A picture would help.
