Slight Knock/Tick in 2001 LS1
Old May 31, 2008 | 12:20 AM
Blue01T/A's Avatar
Exclamation Slight Knock/Tick in 2001 LS1
I have started noticing a slight knock from my motor. I have donne the screwdriver to the ear test on the valve covers and have determined it is not the valve train. It is almost too quiet to be a rod and almost goes away completely once the engine is at operating temperature. I have heard something about GM over boring the #7 cylinder and that causing piston slap. Can anyone help me out here? What could this be?
Old May 31, 2008 | 03:55 AM
Crimsonnaire's Avatar
Was this sound with the car when you first got it? Which side is it coming from? How fast is the sound at idle RPM? Does it consistently follow the RPM at higher speeds?
Old May 31, 2008 | 07:10 AM
CamaroZstyle28's Avatar
Sounds like piston slap .. If only done when cold I wouldn't sweat it to much.
Old May 31, 2008 | 08:54 AM
SOMbitch's Avatar
Yep. Somebody posts a thread like this every week
Old May 31, 2008 | 09:22 AM
z28_YOU_HO's Avatar
whos *** is that SOMbitch ???
Old May 31, 2008 | 11:03 AM
Datzneat's Avatar
Mine made that noise also until I fixed my afr.
