Is there a replacement for the 941 spring without machining?
Old Aug 11, 2003 | 11:44 PM
FAST99Z's Avatar
Default Is there a replacement for the 941 spring without machining?
Agostino stage 2 heads and cam on a 99 z28.
Do 918s fit?
Does anything else fit?
Old Aug 11, 2003 | 11:53 PM
ne14a6t9's Avatar
Default Re: Is there a replacement for the 941 spring without machining?
918's will fit, you need stock retainers
Old Aug 11, 2003 | 11:56 PM
FAST99Z's Avatar
Maybe I am wrong but I was told the Agostino heads I have are an earlier version that won't tke the 918s?
The valve stem diameter is wrong.
Old Aug 12, 2003 | 11:47 PM
FAST99Z's Avatar
ttt, anyone else think the 918s will work?
Old Aug 13, 2003 | 08:59 AM
Paul F's Avatar
You need to check with ARE on this. If they changed the valve stem diameter then there is no retainer that will work with the 918s. In that case you'll need to stay with the 941s or something like the Isky 295Ds.
