Callies Rod Bearing Question
Old Jun 7, 2008 | 03:44 PM
bichin95redta's Avatar
Default Callies Rod Bearing Question
Rod bolts (ARP) are radically different in size between what I ordered for my Callies Compstar H-Beam forged stroker (6.125) rods, and OEM LS1 cracked-cap rods.
Now for the stupid question: I'm using an Eagle forged 4340 crank....will OEM size rod bearings work with this combination? Anyone know if Clevite, Federal Mogul, etc., have a part# for a coated rod bearing that will work with my set up?
Old Jun 7, 2008 | 08:49 PM
67SS509's Avatar
10 Second Truck Club
Here you go.
http://www.lingenfelter.com/store/cb663hnk.html
Lot's of sponsors on here carry them.
Old Jun 7, 2008 | 09:21 PM
KCS's Avatar
KCS
Moderator
The ARP's are gonna be a 7/16 rod bolt while the stock GM ones are a metric, like M9 I think.
But anyways, a Clevite 663H rod bearing should work, but you may need a 663HX combination to get proper oil clearance. The 663H is for a 2.100" crank pin and a 2.2247 rod housing. If you got the SJ Compstars and turned the crank down to a 2.00", then you'd need the 745H.
Old Jun 14, 2008 | 06:02 PM
Thanks, all!
I searched every web site I could think of, and made numerous phone calls. After sifting through all the information, I went with Clevite CB663HK rod bearings.
Old Jun 14, 2008 | 06:05 PM
Tom@SpeedInc's Avatar
663HK and 663 HNK are basically the same bearing, I believe the Narrowed bearing superceeds the first number.
Old Jun 14, 2008 | 06:28 PM
I ordered coated bearings, so I'm assuming this is what the "K" means? The bearings are definitely coated, and they seem to snap into both the rod and cap (upper/lower) ends just fine when I did a "trial check". They gotta be right.....I hope.
Anyway, thanks for the information. There's dozens of detail mistakes you can make ordering parts for a rebuild.
