LS1 or LS6 block. please help
Old Jun 13, 2008 | 08:46 AM
Big Bird WS6's Avatar
Default LS1 or LS6 block. please help
12561168
there is my casting number. anyone know what blcok i have?
Old Jun 14, 2008 | 06:53 AM
PONTIAC SLP's Avatar
Cool yep :)
15% of 01s and 25% of 02's got the LS6 Block. The only way to tell 100% is to check the casting number. As you can see in the above pic (my ls6 block ) the casting number is at the top of the deck on the drivers side. Take a mirror and place it behind the block and check or jack up the car and attempt to look from the bottom. The "easier" ways are the casting hue and bulleye methods but none are conclusive. If you really want to know if you have the block you'll need to do the work and look for yourself, end of story.
Once you have determined if you have an LS6 block (ya you), then the only benefit to the block are the bay windows.
Its generally accepted from most engine builders that if your going for an extreme setup that the LS1 block offers more structural strength over the LS6 block.
some people said the LLS6 block increase some HPS looooooool no thats wrong its same LS1 block sooooooooo THE LS6 BLOCK DOES NOT INCREASE HP, REPEAT AFTER ME "IF I HAVE AN LS6 BLOCK IT DOES NOT INCREASE POWER". LEARN IT, SAY IT, REPEAT IT.
Old Jun 14, 2008 | 09:38 AM
thanks bud.
so is the ls1 blcok stronger then the ls6 block?
and i have my block out. it has 36,000 miles on it. came out of an 02ceta. what is it worth is long block form?
Old Jun 14, 2008 | 10:21 AM
yes LS1 strong than LS6 , i hope any one help u with that
Old Jun 14, 2008 | 01:47 PM
snake charmer's Avatar
on auction sites they price around $2k-$3k depending on accessories and harness .
if it is just the complete block with head and intake maybe 1500+
Old Jun 14, 2008 | 04:56 PM
AU N EGL's Avatar
LS6 blocks do have better oil galleys and coolant chambers then LS1 blocks.
Does it matter? depends on your use
