what is the best cam
Old Aug 15, 2003 | 10:01 AM
snakeeater2's Avatar
Default what is the best cam
what is the best cam that i can get for the money
Old Aug 15, 2003 | 10:29 AM
Tin Indian's Avatar
Default Re: what is the best cam
A FREE ONE!
____________________________________
Seriously, Best for what? ...
1. Max high rpm power when used with stock heads?
2. Max high rpm power when used with ported heads and headers
3. Best low rpm torque and throttle response off idle
4. Best overall torque and HP with stock-like idle
5. Best overall torque and HP regardless of idle quality
6. Biggest cam avail that will not require PCM tuning.
7. etc...etc...etc
There are literally hundreds, if not a thousand cam posts in the archives. Hit that little "Search" link up at the top of the page. You will find more info than you would ever want to read.
Old Aug 15, 2003 | 11:49 AM
TomQ's Avatar
A FREE ONE!
7. etc...etc...etc
Definitely get that one, i heard those are the best bang for the buck!!!
Old Aug 15, 2003 | 12:45 PM
dug's Avatar
dug
Do a search you lazy bastard.
Seriously though get a cheap used one. Most of the cams are within 10-15hp of each other.
Old Aug 15, 2003 | 12:54 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
I got mine used in "parts for sale" on this site.
It's a great street/strip cam.
Old Aug 15, 2003 | 07:20 PM
DaleMX's Avatar
Consider what your car will be when your finished modding. All the parts work as a team so selection is critical. Dont get a huge cam if your not going to spend the bucks for an LS6 manifold and Long Tube headers and a catback, or if you have to be emissions legal. Take your time and think about what you really want. Stick around here and keep reading the posts and you'll get a better idea of what your dealing with. I suggest that you visit the other forums and read as many posts as you can.
Good luck.
Old Aug 15, 2003 | 07:39 PM
99 Black Bird T/A's Avatar
The following is a good primer on cam selection.
http://www.ls1howto.com/index.php?article=23#camhelp
