electric waterpump thermostat?
Old Jun 16, 2008 | 08:11 PM
gvzo6's Avatar
Default electric waterpump thermostat?
How do you remove the tstat from the stock housing?or do i need to get a different housing
Old Jun 16, 2008 | 08:13 PM
MeentSS02's Avatar
Kleeborp the Moderator™
You can use the same housing, you just need to remove it...just push down on the tab while you turn it. You'll have to press hard, but it isn't that bad.
You'll only need the SB Chevy thermostat in the upper neck.
Old Jun 17, 2008 | 06:00 AM
gvzo6's Avatar
got it thanks
