TTP Equalizer 3 cam with a 383 stroker
thanks
sam
The cam makes really good power when the motor's compression isn't down in every cylinder as confirmed by the free compression test that you received..
It's been our open policy for over the course of the last year to be releasing all of our specs publically.. It's not like Comp gave us a special grind than no one else has. All of us competitors call our cams something different, but we pick from the same lobe charts as all do...
If you just gave us a call I would have been happy to provide the specs:
234 Intake @ .050
238 Exhaust @ .050
.595
.602
112LSA +/- Timing Advances made with Adj Timing Chains
The cam will work in a 383, but there are other cams that we have proven to make more torque across the curve and power above than the Equalizer V.3
