Crazy Cam Install Question
Old Jun 22, 2008 | 03:55 PM
04dgmsilv's Avatar
Default Crazy Cam Install Question
Has anyone ever dealt with a cam in which one of the sprocket bolts is not correctly threaded? I am in the middle of my install getting ready to pull the old cam out and I cleaned the new cam up and put some oil on it. Next I tried to install a couple of the waterpump bolts and 2 of 3 threaded in by hand, the third will not (will only go a couple of turns, I did try the sprocket bolts as well, but same thing).
I will contact the vendor tomorrow, but has anyone ever dealt with anything like this?
Thanks
Old Jun 22, 2008 | 03:59 PM
rknyls1's Avatar
Try taking a tap same size as threads. Run it through to clean them out
Old Jun 22, 2008 | 04:40 PM
04dgmsilv's Avatar
Thanks, That is gonna be my first fix to try, but I only have SAE taps on hand, gonna have to go buy one.
Old Jun 22, 2008 | 04:46 PM
Funkster's Avatar
Damn misleading thread title. I came in expecting a cam question regarding like a 280/280 108 LSA install.
Old Jun 22, 2008 | 06:59 PM
Red96TA's Avatar
same here. good luck to the OP though. that would be covered under manufacturer defects though im sure...just fyi if you wanted to warranty it
