swap torquer 2 for a VRX5?
Old Jun 25, 2008 | 11:41 PM
sidewayz28's Avatar
Default swap torquer 2 for a VRX5?
Hi all... im kind of contemplating on getting a larger bumpstick now that i have a daily driver..
Currently i have the texas speed torquer 2 (232/234 .595/.598 112), along with stock 243s, 90/90, LTs, true duals etc.. motor makes #s in sig N/A on a mustang dyno..I also have a nitrous plate kit on tap and have just a 100 shot hooked up for now. The interenals are stock and i dont feel like getting a good head right now because once this motor goes im going to be building something better. So in the long run, this makes more sense for me..IM REALLY digging these Vengeance cams, all of them seem to make awesome power. After speaking with Ron through e-mail he suspects i could get a 15rwhp increase. The VRX5 is a 236/238 .601/.605 113 LSA....Its a bit larger then the Torquer 2.. I'll be running 3.42 gears until i blow the 10 bolt up... Should i man up and get something even bigger?
Also, i just recently got the car dyno tuned after i put the heads, 90/90 and true duals on. Will a cam swap like this mess up the tune? I have a wideband so i can check out the AFR.
Last question, im running Patriot Golds right now, ive had them for the past ~10k (estimate), should i get them checked out? or should the be good to go?
sidewayz28's Avatar
check my f-quick for complete mod list..
Old Jun 26, 2008 | 11:44 AM
sidewayz28's Avatar
tt any one? worth it to get something larger or what?
Old Jun 26, 2008 | 11:54 AM
TXZ28LS1's Avatar
i honestly dont know if the gains from the T2 to the VRX5 would be enough to justify the money and time spent on it. i also was interested in the VRX5 as well. what kind of heads did u put on?
Old Jun 26, 2008 | 12:01 PM
JScamaro's Avatar
I've seen a lot of very good results from cams in that duration range (230-238). I don't know if its worth the swap money wise unless you can do the install yourself.
Old Jun 26, 2008 | 12:20 PM
sidewayz28's Avatar
i do the work my self... im running stock LS6 heads. I dont plan on spending the coin for a nice head until i build a motor.
Its either swapping cams or getting HP tuners.
But Vengeance Cams are kick ***, ive already decided that..
Old Jun 26, 2008 | 12:22 PM
sidewayz28's Avatar
im tossing this idea around b/c i already have the valvetrain to go with it.. The only thing i can see having to POSSIBLY replace are my push rods
Old Jun 26, 2008 | 12:25 PM
sidewayz28's Avatar
you have a badass car TXZ28
Old Jun 26, 2008 | 01:53 PM
SpeedWorld's Avatar
I just bought a VRX5 and I'll be swapping my TR224 out for it, should be quite a big difference
Old Jun 26, 2008 | 02:00 PM
TXZ28LS1's Avatar
thanks man!! its stupid fast dude..
Old Jun 26, 2008 | 02:11 PM
sidewayz28's Avatar
hahaha^
yeah your going to probably **** your self going from a 224 cam to a VRX5
Old Jun 26, 2008 | 02:19 PM
s346k's Avatar
put a vindicator in it...if you're going as big as a vrx5 - stop being a *****. the car will drive the same with a good tune, but make more power.
Old Jun 26, 2008 | 02:34 PM
sidewayz28's Avatar
YEAH vindicator sounds good but i dont know if it will work without fly cutting?
Old Jun 26, 2008 | 03:16 PM
s346k's Avatar
it will work just fine. as long as you used .055 gaskets.
Old Jun 26, 2008 | 03:36 PM
sidewayz28's Avatar
i used a stock MLS gasket... cant remember size.. ill have to look it up
Old Jun 27, 2008 | 03:49 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I'd take that 15hp gain bet any day of the week. I've dyno tested comp lobes in that area & only seen 1-2hp gains with losses down low. Maybe you can offer to buy the cam if it really gains that 15hp. If not they can have it back & pay your labor!?!?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jun 27, 2008 | 04:01 PM
sidewayz28's Avatar
i'd love to do that... Jason i believe you have a PM from me regarding a clutch.
Unfortunately, i just found out my clutch is slipping. So a cam upgrade is going to have to wait. And your right, i honestly couldnt see me gaining much power with 4 more degrees of duration.
Maybe in the future ill run something along the lines of a 240/240, 6xx"/6xx" or something
Old Jun 27, 2008 | 04:06 PM
Dragkid1917's Avatar
i dont think you would gain that much either. Plus TSP's cams run good, I didnt put down the dyno numbers i wanted but then when i went to the track and ran what i did with mods in sig (no pulley or 92/92.. just stock ls1 intake/tb), not even on a full run... I really couldnt ask for much more.
Old Jun 27, 2008 | 04:15 PM
sidewayz28's Avatar
yeah, true^
I think im leaning towards a custom cam anyways.. I want the car to run like a raped ape on spray
Old Jun 27, 2008 | 05:02 PM
SIC LSX's Avatar
I would just keep the t2 cam and put that $ into having your heads ported
