ls1 piston question
Old Jun 26, 2008 | 09:05 PM
Xtremedueces's Avatar
Default ls1 piston question
Hey guys I bought a 5.3 ls1 and I have gone into the motor more than I expected. I purchased a z06 cam, intake, I am porting the heads and purchased new valve springs and many more bolt ons. I recently discovered the crank in my motor is the same part numb the 5.7 has. Can I make a 5.7 by just buying some 5.7 pistons and having the block bored out? Is there anything else I would need to do ( fuel injector upgrade, oil pump, ect...)
Thanks
Old Jun 26, 2008 | 09:11 PM
chevyguy7802's Avatar
Yes you can have the block bored to fit ls1 pistons.....I just recently did this and went with forged mahle pistons(standard ls1 bore).
Old Jun 26, 2008 | 10:36 PM
So in other words since I can pick up a set of pistons relatively cheap ( stock low milage) add new rings, is this something you guys would do?? HP gains?
Old Jun 26, 2008 | 11:46 PM
Yea you can do that.....your prolly gonna have to have it balanced since your mixing diff pistons and rods with diff crank. There are a few people that have done that to stick on a budget. Im not sure on the hp gains tho......
Old Jun 27, 2008 | 12:20 AM
BigBlockCamaro's Avatar
Yes! Thats actually the way alot of people make IRON ls1's! instead of the aluminum ones, which is a good idea if your going to boost the motor!
Old Jun 29, 2008 | 09:02 PM
So If I do this I am now questioning my heads. Is it true that the 5.3 heads are better than 5.7 stockers? Or am I misreading some stuff. If I bore it what recommendations you guys got on a budget. Remember I am running the Z06 cam
