FAST Vacuum Line
Old Jun 28, 2008 | 10:01 AM
1stz06's Avatar
Default FAST Vacuum Line
I just put my car back together after have new springs installed on my AFR's. My car is now running pretty bad..I think because I dropped my MAF.
Anyways, I ordered SS hardware kit from Thunder Racing and new port seal gaskets for the under side of the FAST Intake while I had it out.
On the passenger side of the FAST Intake, there is a small vacuum hose that runs to the HVAC. I put my mouth on it to make sure I could move some air and I CAN'T. I got about 18" of coat hanger through it to see if I could creal it out but still no air movement either way.
How concerned should I be??
Can I say F* It and move on??
What can I do to fix it??
Please help.
J.R.
Old Jun 28, 2008 | 11:17 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
like I said in your other thread
If it is a hard plastic line it's for the HVAC. Does it go into the wiring harness on the passenger side?
