Last evening with the 83'
Old Jun 29, 2008 | 02:12 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
Default Last evening with the 83'
This motor has stood the test of time and exceeded every goal I initially had for it. For you guys that dont quite have the scratch for a larger stroker or simply dont want the hassle of converting to an LS2 based shortblock, the 383 stroker (stock 3.900 bore with a 4" arm) should certainly be a prime consideration for you. Half the reason I built this engine three years ago was to dispel some of the myths that they couldn't make power. I knew with the right heads/cam/induction and attention to detail in the build that would easily be proven to be more "Internet folklore".
There are a handful of threads discussing the build specifics of this engine and its performance but here are just a few of them for the newer crowd among us.
https://ls1tech.com/forums/showthrea...450&highlight=
https://ls1tech.com/forums/showthrea...104&highlight=
https://ls1tech.com/forums/showthrea...446&highlight=
That said I am very much looking forward to the larger 447 CID build I have in the pipeline (featuring a new larger addition to the AFR cathedral Gen III heads), but unfortunately it will be many months before that project is finished. To the guys who are certain to ask about the new 235/240 ish head we are going to release, my only comment is they will be worth the wait (for more reasons than just flow numbers) and are still months away (my R&D efforts at AFR have been focused in other directions although I am close to finishing the new Gen III prototype).
Here is a quick improptu video a coworker took of my car the last Fri night it roamed the streets a week or two back. Honestly the vid quality isnt that great but the soundclip is worth the minute of your life it takes to load it....it literally was the last few blasts to redline this engine had the pleasure to hit as it seemed it was always the happiest screaming big RPM's at WOT. I took her apart the very next day.
BTW, this run would have been a little longer than the actual quartermile for me (where this car normally traps around 130 MPH)....in this vid I take fouth gear till the shiftlight comes on which is just shy of 145 MPH.
Enjoy....
http://www.youtube.com/watch?v=5Ie92hZeOfU
Regards,
Tony
Old Jun 29, 2008 | 03:03 PM
aNuBiS's Avatar
Cool vid and anxious to see this new motor and head combo! I cant imagine!
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Working link: http://www.youtube.com/watch?v=5Ie92hZeOfU
Old Jun 29, 2008 | 03:17 PM
Flow Wizard
LOL....Thanks Joeseph
I updated the original thread with a working link!
Tony
99blancoSS's Avatar
Nice! You know I like the sound of it.
Old Jun 29, 2008 | 04:19 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
What sort of benefits beside flow numbers are we going to see with the new heads over the current versions? What block are you planning to use for your new engine?
Old Jun 29, 2008 | 04:21 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Man...can't wait to see this next one. That 383 was sick...
