rod bearing problem?
Old Jun 29, 2008 | 07:40 PM
superLS1camaro's Avatar
Default rod bearing problem?
i have a 99 ls1 it had 90 k on it..... before i spun a rod bearing. i had to have the crank weld and refinish... i bought new main bearing,,rod bearing and arp rod bolts.. so should i worry about this happen again??????
Old Jun 30, 2008 | 11:04 AM
conde'strans's Avatar
If the job was done correct I don't see why it would happen again. Mine is currently getting the same thing done to it.
Old Jun 30, 2008 | 11:27 AM
98RedBird's Avatar
You're going to need to find out what made that rod bearing spin such as lack of oil. Otherwise, yeah, I'd worry about it happening again.
Old Jun 30, 2008 | 01:00 PM
Engine_HP's Avatar
i agree with both posts up.
but still nothing to be afraid of #1 make some good inspection #2 try ur best to get the job done correctly.....
plus u can find things to help u www.ls1howto.com
Old Jun 30, 2008 | 03:47 PM
5_02ls1's Avatar
I would replace that rod.....
