cheater cam gains?
Old Jun 30, 2008 | 11:01 PM
EricT's Avatar
Default cheater cam gains?
What kind of HP gain could I expect by going w/this cam ; CheaTR" - 214/230 .601/.575 117 LSA?
Old Jun 30, 2008 | 11:04 PM
Bluvette28's Avatar
is this with or without heads
Old Jun 30, 2008 | 11:22 PM
180ls1's Avatar
search the dyno section i believe one guy picked up 34 horsepower tuned, it also depends on the year of your car because the 98-99 had bigger cams then the following years.
Old Jul 1, 2008 | 12:07 AM
EricT's Avatar
stock 2000 C5 MN6, catback exhaust and will be installing a Vararam and an underdrive pulley at the same time. Would like to be around 350 RWHP.
Old Jul 1, 2008 | 03:10 AM
PREDATOR-Z's Avatar
yeah, it will do that easy.
But being a 2000 (rod bolts being an issue), I would consider a cam with lower shift points. Something like 214/224 .600/.600 113+2 LSA
Old Jul 1, 2008 | 09:30 PM
EricT's Avatar
What does lower shift points refer to? How much of an issue are the weaker rod bolts, if I pushed it to 400-450 RWHP would I need to change them out? Thanks for the responses.
Old Jul 2, 2008 | 01:06 PM
5_02ls1's Avatar
what he means is that your gonna be turning past 6500 with that cam...
Old Jul 3, 2008 | 12:20 AM
EricT's Avatar
Ahh, thanks. How about the MTI X1; 230 227 .591 .571 112? Will that one not have to spin as high? Would my best bet be to talk to Patrick G and pay for a custom spec'd cam?
Old Jul 3, 2008 | 09:55 PM
fuzzyjk's Avatar
CheaTR cams are designed to be used stock manifolds. I would say 350 Rwhp should be no problem
