All stroke 395 CI motor?
Old Aug 20, 2003 | 06:36 PM
robertbartsch's Avatar
Default All stroke 395 CI motor?
I'm considering a stock aluminium block motor with a 4.125 stroker crank.
Someone here said it will be a turd becasue the stroke is too long for the bore.
How much will I have to dish the pistons if I will use 60CC chambered LS6 heads that have already been milled .055?
Your thoughts?
Old Aug 20, 2003 | 07:42 PM
kumar75150's Avatar
Default Re: All stroke 395 CI motor?
I dunno about it being a turd. Mine made 484rwhp peak last month with 3.42 gears.
Old Aug 20, 2003 | 08:00 PM
XLR8NSS's Avatar
Adkoonerstrator
Heads/Cam/Car details would be nice.
Old Aug 20, 2003 | 08:47 PM
kumar75150's Avatar
MMT in Texas did it. I didnt want problems with dropping sleeves etc.
Their stage 2 heads with 2.02/1.57 valves and a big *** custom cam: over 240 duration and .600 lift. Its on a 02Z06 with all the bolt ons.
Waiting for one of the new intake manifold.
Old Aug 21, 2003 | 09:43 AM
...I'm thinking the same. Don't want dropped sleaves and a Darton wet sleaved block is $3.5K...it does not seem worth the $.
I like low end torque...
Old Aug 21, 2003 | 10:54 AM
Vents's Avatar
well, speed inc, has them for under 2k now.. probably less than that crankshaft is going to cost ya.
Old Aug 21, 2003 | 12:14 PM
CHRISPY's Avatar
484RWHP is nice! Good stuff
cheers,
Chris
Old Aug 21, 2003 | 04:24 PM
kumar75150's Avatar
Thanks
I want to save up for one of those C5R blocks, especially if they come down under $5000 one day.
A 434 should put me around 520rwhp.
Old Aug 22, 2003 | 04:01 PM
Ragtop 99's Avatar
$2k is just the bare block. Need pistons, rings, etc. for a proper comparison to a stroker crank set-up.
I'd sure like to see a reasonable priced stroker kit, but maybe the resleeved blocks will be the only affordable option. They seem to be getting cheaper.
Old Aug 25, 2003 | 08:34 AM
Is'nt the stroker less expensive than a wet sleeved Darton block? Callies makes the crank for $1,800.
The block with machining is about $3K; then add pistons, rings, etc and your way over $4K...
