pushrod length
Old Jul 8, 2008 | 11:37 PM
GoodlookinLS1's Avatar
Default pushrod length
need help with sizing. heads are trick flow 225 milled to 65cc and i also have ls7 lifters. gm ls7 mls head gaskets. this is in an lq9 408 also
Old Jul 9, 2008 | 12:02 AM
99blancoSS's Avatar
What cam? need to know base circle
Old Jul 9, 2008 | 12:19 AM
its a 254/254 on a 113+2 lsa .598 lift and 1.7 rockers
Old Jul 9, 2008 | 12:37 AM
skeels's Avatar
People can give you a close guess, but the best way (if you have the time for it to be down) is to asseble everything and then use a pushrod length checker to be 100% sure. They are under $20 and worth it imo.
Old Jul 9, 2008 | 08:19 PM
brad8266's Avatar
You need to use a pushrod length checking tool to get the correct length you need. Without it all you are doing is guessing.
Old Jul 9, 2008 | 10:27 PM
01ssreda4's Avatar
what about with something like a tr224 on factory 241 castings? isn't the 7.4 pretty much standard? sorry for the hijack
